Gear change bit stiff and hard to find neutral
wambam87
Hi guys this is my 2nd post sorry if its a frequently asked question
The vfr nc30 late 1992 that ive just bought , shes been unused for a year , she starts well and runs ok ( going to clean the carbs tommorow ) but the gear change feels very stiff to me and is a bit hard to find neautral , is there a nack for getting it in neautral ? or is there a possible issue ?
Ive also done a full oil and filter change today.
Any info would rock :D
- Deviant400
Re: Gear change bit stiff and hard to find neutral
i find i let the clutch bite a little bit blip the throttle and it should go in , there is a knack to it soon becomes second nature
viewtopic.php?f=62&t=27307
wambam87
Ahh ok cool cheers. I paniced because when i removed the fairing to do the oil change there was no grease / lubericant on or around the gear leaver / pushrod or were it goes into the gearbox , shes all lubed up now tho !
Delboy
They love a bit of lube
but as Deviant said, just a little blip of the throttle and that lil green light will appear as though by magic lol!! It's a knack.......
nazzurro_19
- Bike owned: Honda NC30
I find mine goes into netrul quite easyily, if not just accelerate forward in 1st like 2 iches and it will go straight in
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
Blip the throttle to about 3000.
wambam87
Thank-you for the tip , there is definetly a nack tho. On a second point what roughly is the top end for the nc30?
Delboy
what do you mean?
Speed wise?
Speed wise?
wambam87
aye sorry didnt make that clear
This is my first vfr , shes been sat for a year and is still running a bit lumpy at the moement but a couple of long rides today has helped no end. itl need some more tlc in the next few weeks , So far ive changed , Oil , oilfilter , cleaned the carbs ( got out nasty mouldy petrol) running a bit of redex through it as well. And next weekend i hope to do airfilter and new plugs. Is there anything else you recomend i do ?
- Deviant400
think you will have covered the basics doing that , oil/oil filter, air filter , plugs , carb clean re-set then onto drive, so chain/sprockets, then shocks 20year old bike so there tired by now , rick oliver spring kit for the front forks (best £80 you could spend on the bike) then get a rear shock , either refurb the original or swap out for a pricey one what ever floats your boat , that would be my way of doing things , then look at pipes bodywork etc till your happy , haha its a never ending story really depends how far your prepared to go
