Testing a stator off the bike
spongy.bob
Similar question to my last one:
Can a stator be reliably tested off the bike? Or at least without having to put the left hand engine casing back together and start the bike?
kevprojex
- Bike owned: ktm200exc gsxr400gk71b sv650
Re: Testing a stator off the bike
You can test for continuity between the three phases, and check each phase down to earth on the centre steel part.
- Bike owned: VFR400
Between the three yellow leads you should measure approx 1 ohm and from yellow leads to metal frame infinite resistance.
spongy.bob
So the test in the manual works whether the stator is on the bike or off? (provided the reg/rect is disconnected)
