socket sizes
- Deviant400
socket sizes
im off down me mates workshop to torque up the essentials tomoz so i need to take a pile of sockets
but cant remember the front axle bolt size
rear hub 46mm
rear wheel 36mm
top yoke 41mm
front axle bolt ???
rear hub 46mm
rear wheel 36mm
top yoke 41mm
front axle bolt ???
viewtopic.php?f=62&t=27307
Re: socket sizes
I have 22mm and 24mm axle bolts..so take both!
- Deviant400
Re: socket sizes
cheers , will do
scotjell
- Bike owned: VFR400 NC30x2
Re: socket sizes
Don't forget the socket to torque up the clamp bolts too.
- Deviant400
Re: socket sizes
yeah ill have all them smaller sizes at me mates workshop, he does tinting and wrapping so only really has basic sockets and tools needed for what he does , all the big stuff ill take with me, my plan is to go over everything and just check all is torqued up as per the manual , MOT on the horizon
- Deviant400
Re: socket sizes
17mm hub pinch bolt too i belive ?
Re: socket sizes
was gonna say the same, some have 22, some have 24 for some odd reason i have neither i have a special hollow one for my fork crash bobbins :DCMSMJ1 wrote:I have 22mm and 24mm axle bolts..so take both!
- Deviant400
Re: socket sizes
is that a whole front axle you got then ricky that allows the bobbins or do they bolt through the standard axle , and i think mine is a 24mm come to think of it
Re: socket sizes
no its just the nut you replace so a 6mm or 8mm rod slides through and the mushrooms go either end,Deviant400 wrote:is that a whole front axle you got then ricky that allows the bobbins or do they bolt through the standard axle , and i think mine is a 24mm come to think of it
www.coyotemoto.com
ive quoted them about 3 times this week, i should get commision :D
scotjell
Re: socket sizes
I was wondering as seen you quote them on most of your posts.
