NC 30 Rear wheel stuck on shaft
Ashspider
Post by Ashspider »
Undone the nut but the wheel is solid. Any suggestions for easing it off.
Thought about a bit of steel behind the spokes on the drive side an another longer piece going across the shaft with the nut back on to protect the end. These pieces will then be tied together with threaded bar to gradually pull them together and pull the wheel off the shaft. Tried a rubber hammer and a bit of penetrating fluid but no joy.Am I missing a simple solution. It has been stood a while.
porndoguk
Re: NC 30 Rear wheel stuck on shaft
Post by porndoguk »
Ashspider wrote:Undone the nut but the wheel is solid. Any suggestions for easing it off.
Thought about a bit of steel behind the spokes on the drive side an another longer piece going across the shaft with the but gack on to protect the end. These pieces will then be tied together with threaded bar to gradually pull them together and pull the wheel off the shaft. Tried a rubber hammer and a bit of penetrating fluid but no joy.Am I missing a simple solution. It has been stood a while.
Block of wood and twat in from the sprocket side, rotate wheel in quarters and hit it again its a common problem
brute force....twat it
Ashspider
Post by Ashspider »
Better get a bigger persuader then
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
and some copper slip to rub on the contact points when you put it back on ;)
Deviants AM/PM build
viewtopic.php?f=62&t=27307
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
serious amounts of brute force at quarterly turns.
scooble
Post by scooble »
I got a bearing puller and a cylindrical tube to push against the axle. mine was proper tight and took a big spanner and lots of torque to get it off. Eventually it popped off and I gave the shaft a good clean with emery cloth and re-assembled with copper slip
CRM
Admin NWAA
Admin NWAA
Post by CRM »
i bet some clown has powdercoated the wheel and not bothered to clean up the inside mating surface of powder when they but the wheel back on.
brute force is the only way
make sure you clean the inside of the wheel up with a dremel after to stop it happening again
VFRkieran
Post by VFRkieran »
This is exactly what i did last week and it works a treat :up:
