NC30 Race Bike Wiring?
h2o-pro
I know this has probably been covered before but I can't find a thread that gives me a definitive answer...My race bike harness had been hacked around so I have stripped it down and got rid of everything I don't need...I have also left it charging... I need to know what do I do with the clutch diode wires? I have no clutch switch & the diode is missing anyway...There is a connector with a green/red & lightgreen/red wire... Can anyone tell me 'politely' what to do with these wires so that I can eliminate this circuit from the harness?
- Bike owned: VFR400
Re: NC30 Race Bike Wiring?
You need to connect the red/green wire to the chassis to complete the starter solenoid circuit, the light green/red wire will have no function. If you want to remove this wire pair from the loom, connect the red/green wire at the starter solenoid directly to the chassis.
h2o-pro
Thanks...that's what I'll do!
