NC30 tools for general maintenance.
- Worther
Hi,
I've done a quick search and couldn't find what I would like to know so here goes...
...what 'Honda specific' tools do I need for general maintenance & how muh to pay/where from?
I have most sizes of sockets etc, but I realise I need a 'chain adjuster' tool & a rear 'wheel nut' socket. Are these the main ones?
I've seen 'chain tools' on eBay for around £17, what do you guys recommend?
Can I get these tools from a 'normal' Honda dealer?
Any advice would be appreciated as funds are low..
Thanks,
Rich
Thanks,
Rich
Re: NC30 tools for general maintenance.
The Chain / Shock C spanner is part of the standard NC30 toolkit.. You can buy the stock Honda one for less from David Silvers / any Honda dealer.. its' two parts.. the spanner and the handle.
The aftermarket ones usually have a built in longer handle which can be convenient but they don't fit well under the seat if you want to take them with you.
The wheel nut is a standard size (can't remember off the top of my head) so just need a normal socket for it.
The only 'special' tools you'd need are the castellated socket for removing the swing/arm / engine.
41MM yoke nut
48MM? Hub nut? (i think)
36MM Wheel nut
36MM Wheel nut
- Worther
Thanks for the replies, that's just the info I needed. Better get ordering ready for when/if the rain ever stops!
- vfrman
- Bike owned: NC30, 1098s
Rear hub nut is 46mm... I know because I need one!
- Deviant400
vfrman wrote:Rear hub nut is 46mm... I know because I need one!
viewtopic.php?f=62&t=27307
i did initially put 46 and then thought i was getting the 6mm mixed with the wheel nut, problem i have is i have an A/F equivilent socket
so cant quote the size,
