bit wobbly RVF 400 air intake ducts????
majormadass
- Bike owned: CBR125R, VFR400 NC30, RVF 400
hey guys, just wondering, on the rvf 400, the ram air intake ducts, at the front of nose cone on my RVF seem a little shaky? is this normal? i've looked up like aftermarket TYGA ones, and they don't seem to have a rubber housing or anything to keep them snug? they only bit shaky/wobbly if you wobble em with your hand? is this normal?
Mavirick
- Bike owned: NC35
Re: bit wobbly RVF 400 air intake ducts????
Its the same on mine but im taking them off and modding the nosecone so i dont have to put them back on
majormadass
i mean, they ain't major wobbly, takes a hard wiggle with your hand to wobble them, i'm guessing this is normal then???
amaechizzle
- Bike owned: NC35
Wouldnt really worry about it, they're not structual.
You could try 'adjusting' the upper fairing bracket, but that would in turn 'adjust' the side view mirrors... If you use them.
By 'adjusting' the upper fairing bracket, your effectively tightening the area between the front of the air duct, and the top of the tank, slightly unnecessary. (spelling?)
Or where the air duct sits on the top of the tank, there should be a screw on the outer side towards the front of the bike, try tightening that... My bike doesn't have the screws at all, I low-sided my bike not long ago on the left hand side, pulled the bracket back into shape, and the air duct is tight as hell!
majormadass
ahh i see matey :) thanks for the advice, i was just wondering if it's normal, i'll try to tighten my bracket etc :) had a look today, i think that will work :) and yeah i got the single screw on each of the air duct on the inside? so yeah i'll tighten them too :) thanks buddy!
