RVF luggage options
Tam55
- Bike owned: NC35 & RMZ250
RVF luggage options
I had noticed that Ventura have a rack listed for the NC30 but not the NC35. Now I know that the 30 and 35's subframes are different but without seeing the pair of them side by side I don't know how different. Does anyone know how the Ventura system mounts up to the NC30 and whether or not it can be modified (without major rewelding work ) to fit the NC35?
If not I'm guessing it's back to the trusty soft panniers and maybe a tailpack.
Tam
Tam
- CRM
Re: RVF luggage options
quite different i think if i recall. more the width and location height of the rack.
i used a spare pillion seat, and attached a whoppa bag to the seat itself, only around 35l so not huge but with the tank bag i got just about everything needed in
Tam55
Ok cool thanjs fir your reply. I thought as much the bines are so similar yet so different at the sane time. I might just get myself a knackered pillion seat and fabricate a plate or something to bolt on to it, just to give me a flatter surface and more tie down points for loading a tent and camping bits on to.
Tam
Tam
buffalobisonhead
Has anyone any experience of using a tank bag on a NC35?
Any recommendations? Probably wont be used that much, hoping for something that would hold pair of shoes and disc lock.
Dont want the tailpack option as I have a fragile tail piece.
ta
ta
dreison
littlebigman
- Bike owned: NC35
Whatever you get, tank, tail buy Kriega it's quality.
thutchoo
- Bike owned: NC35
I have a red oxford lifetime luggage tank bag that has been used once if you are interested? will definately fit a pair of shoes and lock in, give me a PM
- royster81
I think the Ventura would fit no bother, the under trays are nearly the same and can swap about the subframes so I think it would fit no problem.
I have a Ventura and an rvf but no time to test it
- CRM
Send it to me pal, i will test itroyster81 wrote:I think the Ventura would fit no bother, the under trays are nearly the same and can swap about the subframes so I think it would fit no problem.
I actually wanted that off Gareth, but if ever you let it go - bear me in mind pal
- royster81
Pm me your address and I'll send it to you, i can't see me wanting to sell it as I wanted it to use the next time I come over but if your planning a trip on a 400 and want to use it go for it.
