advice pls
jinxster
advice pls
Post by jinxster »
ok im thinking of putting 600 engine in my 400 apart from engine carbs clocks and ecu is there anything else that needs to be done as havent got a clue lol
Re: advice pls
Do it..
But use the search function - hybrid is a good start.
I had one, raced it, it was wicked.
Re: advice pls
Post by Evilchicken0 »
You need the downpipes.
If it's a 3TJ then you'll need a pair of mounts for the top of the engine
If it'a a 1WG you won't need them and it's a much easier swap.
