My fuel tap is leaking a bit
Mostly where it says on but then any movement will cause fuel to come out of it.
Was just wondering would this http://bikebusinessonline.co.uk/shop/ar ... 0743724%26 let me fix the fuel tap
Re: My fuel tap is leaking a bit
Take the tap apart first, Found out on mine out that the two tabs were broken, you can get repair kits from e-bay but it dosnt include all of that.
Rebuild did the trick on mine. It was leaking fuel out the front and the kit fixed it up.
