3EN1 Rear Shock Options
Posted: Thu Apr 12, 2012 10:18 am
by Clanky
Hi,
My shock is starting to weep oil so I need to look at getting a replacement. I've read that the r6 mod won't work without swapping out the braced swingarm. I can try to get a better original part or have mine reconditioned.
Are there any other shocks that can be used that are pretty much bolt in? I don't mind fiddling with spacers and dogbones but I don't want to be grinding the frame and swapping swingarms to make something fit.
Re: 3EN1 Rear Shock Options
Posted: Thu Apr 12, 2012 10:57 am
by Taggyd
i thought the r6 would fit without the lengthening adapters with just a shaving off the corner of the shock to clear? i've got a working 3en1 shock that came from a running bike if you need one for the mean time, going cheap!
pm if you want it!
Posted: Thu Apr 12, 2012 1:00 pm
by Evilchicken0
The shock "should" be the same as the FZR600 3HE ... if you want to go to the R6 shock I'd suggest you fit a different arm but if you do that then you'd really question whether you want a 17" wheel so it's a bit of can of worms.
Posted: Thu Apr 12, 2012 1:11 pm
by Clanky
Hi Evil,
I've got a 600 that is having a major rebuild so I'm trying to focus on that. Time and money is a factor and I'm trying to keep the 400 as my daily ride (only spending on maintenance to keep it safe/reliable). Like you say it's a can of worms sometimes and I don't want to be tempted spending money on the 400 right now unless I really have to.
Posted: Thu Apr 12, 2012 1:42 pm
by Evilchicken0
I'd buy Taggy's then :peace:
Posted: Thu Apr 12, 2012 5:24 pm
by thunderace
I've been looking into this myself. The options for a straight (possible dog bone change required for ride height) swap are:
2006-08 R6
K1-K4 GSXR 750/1000
CBR600 RR3
ZX6R B & P models.
Posted: Fri Apr 13, 2012 12:41 am
by Clanky
Well I've gone for Taggy's old shock for now, thanks for sorting that out. If there is a confirmed option for a shock with more adjustment I'd certainly consider it for a future mod.
Thanks all for the help.
Posted: Fri Apr 13, 2012 5:40 pm
by thunderace
I've got a ZX6R P8 shock in the post so I'll let you know the crack when it turns up :peace:
