3en2 restricted?
SteveO916
Bike owned: Ducati 916, GSXR750, XR400R
3en2 restricted?
Post by SteveO916 »
can anyone confirm if a 3en2 is restricted by the speedo and will a kmh-mph converter sort it?
can i get away with getting rid of the speedo cable/drive completely and replacing it with a spacer on front wheel?
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: 3en2 restricted?
Post by Taggyd »
been talked about a.lot! yes a mph will lose the top speed restrictor. and no without a modified cdi you cant just lose the cable as the cdi need to recieve a signal from the speedo work.
Post by Evilchicken0 »
You could fit a M-Max (or similar) derestriction box and loose all the speedo gubbins.
