Removal of haft from bottom yoke
Posted: Sun Apr 08, 2012 1:12 pm
by chownsy
As per title, How do you remove the shaft out of the bottom yoke as im sending the yokes off with the frame for powder coating.
Re: Removal of haft from bottom yoke
Posted: Sun Apr 08, 2012 4:15 pm
by porndoguk
chownsy wrote:As per title, How do you remove the shaft out of the bottom yoke as im sending the yokes off with the frame for powder coating.
you dont it will need masking.
Posted: Sun Apr 08, 2012 4:25 pm
by chownsy
ah thanks, Guess ill be sending my NC21 ones off instead then as i tried to push it out with the press and bent the thread
Lucky that the NC21 and NC24 bottom yokes i have are identical
Posted: Sun Apr 08, 2012 4:49 pm
by Chrissy_J
The steering shaft will have been welded into the bottom yoke. To remove it requires the removal of the weld- and it's rewelding afterwards... not something to consider with a refinished yoke.
Mask it off instead, as stated above.
