Front sprocket free play?
mattj92
Bike owned: Nc30 build in progress
Post by mattj92 »
Hey all. Another noob question. One of the last jobs on my project nc23 is a new set of chain and sprockets. I've fitted the new renthal front sprocket and it's tight. But there is very slight side to play between the sprocket and the output shaft. Is this normal with renthals? What could be the problem?
Matt
thunderace
Bike owned: R6, YZF600R
Re: Front sprocket free play?
Post by thunderace »
Shouldn't be any lateral play at all. Are you sure it's the fit of the sprocket and not the output shaft moving? It could well be the output shaft oil seal needs replacing.
mattj92
Post by mattj92 »
Output shaft is fine. Was fine with old sprocket. It's like the renthal is made slightly too thin. Here's a video. Excuse the noise of the gennie. It's a good mil of play along the shaft :/
http://www.youtube.com/watch?v=_n5XUYlk ... ata_player
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Have a look and see if there is any difference between the original sprocket and the renthal one.
Only mentioning this as when i changed mine i received a front sprocket that was not intended for my bike so i rang renthal up (or whoever i bought it from) and they apologised and sent me the correct sprocket for my bike
mattj92
Post by mattj92 »
It's for a vfr. But I got it from Greame France who i trust knows what goes and what doesn't. I'll give him a ring tomorrow anyway. Maybe it's been manufactured out of spec? I don't know :(
thunderace
mattj92 wrote:Output shaft is fine. Was fine with old sprocket. It's like the renthal is made slightly too thin. Here's a video. Excuse the noise of the gennie. It's a good mil of play along the shaft :/
Ah! I see what you mean now, I wasn't quite sure before. Have you replaced the washer behind the bolt head?
mattj92
Post by mattj92 »
The large flat washer? No. Should I?
Could I just wack another washer on there to take up the slack? I know it's not ideal but if it does the job I don't see the harm aha
thunderace
I'm 99.9% sure there should be a lock washer behind the bolt head. Maybe someone can confirm?
tanuki
Post by tanuki »
No there is no lock washer.
My sprocket has a bit of free play but not that much, have you spoken to Graeme?
mattj92
Post by mattj92 »
Didn't get chance. Work was mental. Just gonna stick a repair washer behind the standard nut and washer. Can't see the harm. Not the best mod but no one is gonna see it. Haha
