fairing
				blade400
fairing
Hello too all
I am new here, ive learnt and read some intresting topics
i really need some help from you guys
ive owned 2 cbr400 nc29 over last 10years, my problem ive had is the the fairings keep cracking due the vibration stress on the fixing points (lugs/tabs) cracking them. i could just put a rubber washer on, or maybe a rubber inlet washer (tophat washer) so the screw doesnt touch the fairing atall when attached....will this do? what do you guys use?
does anybody have any ideas, know where i can purchase the original rubber washers or a decent substitute?
ive bought a whole new fairing kit from skidmarx and dont wana put them on without the right washers
thanks, kind regards
blade400
blade400
				gullarm
Re: fairing
I too would be interested.
Would rubber from an inner tube cut into a small washer style suffice to dampen the vibes?
- petrolhead19
Re: fairing
can get the rubber gromets from here: http://www.cmsnl.com/honda-cbr400rrk-nc ... partslist/
Have a look around you will find them. if you cant let me know and ill get the links for you
				blade400
Re: fairing
gullarm..thanks for the idea...i did think of actually making one from some sort of rubber, just something small enough that will fit in the faring hole, and a rubber washer on top...so when the fairing screw goes in and hold the fairings in place no metal is touching the fairing.
but then petrolhead19 made a good suggestion (thank you) about the bush, i had a look at the website...i think its called a 'retainer' but couldnt find a pic of it...can u help petrolhead19
also Evilchicken from the FZR400 post gave me the link for http://www.grommets.co.uk/index.php/products
they have a few good bits and pieces there, def worth a look
oh btw i have found a decent solution for screen screws...their called push rivots
if want to see a pic of them go to http://www.cmsnl.com/products/push-rivet_90116mcsg00/
however i got mine from a company in uk called replicast uk
iv not fitted them on yet as still waiting for my fairings from skidmarx.
you push the push rivots in and then snap or cutt the top bit off, thats just there to insert the rivot in
- petrolhead19
Re: fairing
is it the ones for the rear fairings your after where they join into the tank?
Number 8 and 9 on this link if so
http://www.cmsnl.com/honda-cbr400rrk-nc ... F16-1.html
				blade400
- petrolhead19
Re: fairing
this is the link for nc29 model
http://www.cmsnl.com/honda-cbr400rrl-nc ... t/F16.html
				blade400
Re: fairing
thanks
yeah ive looked at this site before, what i found is that No: 47/48 are the screws that fit the fairings to the frame but no washers or rubber inlets are shown or stated in description. i thought that maybe the washers come with it when ordered. i dnt want to order it and the washers dont arrive.
