needle clip height
Posted: Mon Mar 26, 2012 10:15 pm
by 4hundread
K
Re: needle clip height
Posted: Mon Mar 26, 2012 10:37 pm
by Variablevalves suck
Im sure stock is 3rd down, but if it pulls clean with no bogging you are ok at 4.
Posted: Mon Mar 26, 2012 10:49 pm
by 4hundread
H
Posted: Tue Mar 27, 2012 8:41 pm
by Jaicen
Any chanceof some pics of your needles?
I'm having trouble with mine not revving, seeming to be lean so I was thinking that perhaps the needles are set wrong. I believe that the clip is in the middle of three settings on mine, but you say yours have four?
Posted: Wed Mar 28, 2012 8:33 pm
by 4hundread
R
Posted: Thu Mar 29, 2012 1:18 pm
Turning the pilot screws should clearly change the idle of the bike.
If you cannot tune the throttle hang out with the pilot screws then you have a vacuum/air leak.
Are the pilot screws fitted correctly with the o'ring then washer followed by the spring and then screw?
People fit them wrong and the pilot screws have little/no effect.
