Who to trust to service NC35
				larry
I want my NC35 serviced and would like to know of a garage or somebody who nows what they are doing.I live just outside Cardiff.
LARRY
LARRY
- Speedy
- Bike owned: RVF400RR, ER6n
Re: Who to trust to service NC35
Is D.I.Y. not an option?
What needs doing?
Valve clearances aren't for the average home mechanic, but most other things are fairly simple to do!
							What needs doing?
				larry
I can do most of the serviceing but i think checking the valves is left to the experts.
						- Speedy
All I can say about the valve clearances is, that it takes time to do and you need to be careful not to drop a shim in a cylinder! You shouldn't rush it and you have to be certain that all the necessary steps are followed; such as the TDC and clearance measurements, etc.
Give it a go; you just might surprise yourself and save a load of £££ at the same time!
I had never done it before and even though it took me about 5 hours to do it, I was/am happy I did it myself!
Have a read at ViperBiker's guide on here: viewtopic.php?f=24&t=1943
You might get a headache by the end of it, (especially if you read all 14 pages!) but you'll get an idea of what the job entails!
P.s. A Haynes manual is also useful for this task!
				larry
I will give it a go, thanks for your help.
				scotjell
- Bike owned: VFR400 NC30x2
If in Bristol area bring it over. Done mine loads of times.
						- thunderace
- Bike owned: R6, YZF600R
You're welcome to pop it up to me but I think Blackburn may be a bit too far
						- micpec
Hi Larry, it does look difficult, but remember to get all the necessary toolings, haynes manual and work space but also time and patience. You can do it.larry wrote:I will give it a go, thanks for your help.
Who I trust to do it? Me Myself and I
 Knowledge is power.
 Knowledge is power."Action without Philosophy is a lethal weapon; Philosophy without action is worthless"
						- thunderace
micpec wrote:haynes manual
				larry
Thanks for all your input will try and do it myself have got a Haynes manual and access to this site so hpoefully i should be able to do it if i take my time
