is there a missing bolt also temp gauge its 2 probs
wedge
hi...i finally got round to working on the 3tj after buying it last year...i knew there was alot oil behind the rad on the cylinders..i knew it be coming from rocker cover..but is there a missing bolt???....as you look along the front of the rocker cover(not on top with the other bolts) right in the middle behind the rad theres a little bit that juts out..i've slid a finger down doesn't seem to have a bolt in it should there be,just it being so tight i can't look down to see????.......also i noticed temp gauge no moving at all,,any idea's so i don't have to follow the loom back..and is the temp sensor the one in front of the oil window on the right of the engine????
Taggyd
Re: is there a missing bolt also temp gauge its 2 probs
the jutting out bit should mate with the head exactly, if it doesnt, then the rocker cover is on the wrong way round. There isnt a bolt through it, it's just the 8? silver ones that hole the cover on i believe.
the thermostat is on top of the engine iirc! think you are looking at the oil level sensor??? but it's been a while since i've done anything with either of them!
- laminator
- Bike owned: 2tk,NC30, YB7
It should look like this -
Have a look at the semi circular infils at the end of the cams - if they're cracked then replace the gasket but if you think it's an oil leak from the cam cover then chances are the gasket's to blame.
wedge
i just think the gasket is shot....just that little infill at the middle were the cam chain is i couldn't see if there was a bolt in there...but now i can see there isn't...i'll try get through the summer then come winter be 600 motor i think.
The 600 and 400 cam cover gaskets are the same if you renew it now you can reuse it on a 600 later
wedge
aye but its a pain in the tits to get into the valve cover...its a bit of 9lbs in a 8lb bag with the beast...lol
