gk76a geometry
Posted: Wed Mar 21, 2012 2:44 pm
by ben2306
i've replaced my gk76a with a K7 rear shock. my front was lowered 20mm when i took over. now with K7 shock, i feel that i'm leaning more forward. my friend said that with lower front, corners will be sharper. please advice whether i should adjust front back to stock height or its okay to be 20mm lower. what are the pros & cons? photos of my front & rear with measurement. :peace:
front measurement
rear measured with scale infront of footrest.
front lower by 20mm
Re: gk76a geometry
Posted: Wed Mar 21, 2012 3:02 pm
by Jaicen
You dropped the forks 20mm? That's quite radical if you ask me.
I fitted a K7 shock to my bike. Because it's less soggy, that had the effect of adding about 20mm rear ride height, so my forks are back through the yokes. I think I have them at 5mm now.
Of course, my bike isn't running at the minute...
Re: gk76a geometry
Posted: Wed Mar 21, 2012 6:55 pm
by thunderace
20mm on a 400? :o Are you suicidal?
Re: gk76a geometry
Posted: Thu Mar 22, 2012 4:32 am
by ben2306
well, think i've got my answer!! i'll put back to stock height!! :grin:
Re: gk76a geometry
Posted: Thu Mar 22, 2012 3:23 pm
by panda
What is the stock setting out of intrest mines set at 10mm?
Re: gk76a geometry
Posted: Fri Mar 23, 2012 4:32 am
by ben2306
should be fully @ the top?
