gk76a geometry
ben2306
Bike owned: gk76a
gk76a geometry
Post by ben2306 »
i've replaced my gk76a with a K7 rear shock. my front was lowered 20mm when i took over. now with K7 shock, i feel that i'm leaning more forward. my friend said that with lower front, corners will be sharper. please advice whether i should adjust front back to stock height or its okay to be 20mm lower. what are the pros & cons? photos of my front & rear with measurement. :peace:
front measurement
rear measured with scale infront of footrest.
front lower by 20mm
Jaicen
Bike owned: GK76SP & ER6F
Re: gk76a geometry
Post by Jaicen »
You dropped the forks 20mm? That's quite radical if you ask me.
I fitted a K7 shock to my bike. Because it's less soggy, that had the effect of adding about 20mm rear ride height, so my forks are back through the yokes. I think I have them at 5mm now.
Of course, my bike isn't running at the minute...
thunderace
Bike owned: R6, YZF600R
Re: gk76a geometry
Post by thunderace »
20mm on a 400? :o Are you suicidal?
ben2306
Bike owned: gk76a
Re: gk76a geometry
Post by ben2306 »
well, think i've got my answer!! i'll put back to stock height!! :grin:
panda
Bike owned: 1990 gk76a
Re: gk76a geometry
Post by panda »
What is the stock setting out of intrest mines set at 10mm?
ben2306
Bike owned: gk76a
Re: gk76a geometry
Post by ben2306 »
should be fully @ the top?
