				FZR 600 FOXEYE CLOCK ISSUE
				Posted: Mon Mar 19, 2012 9:33 pm
				by 2strokepowerhouse
				hi guys iv got a little problem with my 400/600, ive fitted the foxeye engine and running gear but when i start the bike the rev needle starts to perform a little dance, is there a wire that needs to be altered? any help on this would be much appreciated! thanks 2SPH
				Re: FZR 600 FOXEYE CLOCK ISSUE
				Posted: Mon Mar 19, 2012 9:42 pm
				by Evilchicken0
				TPS ? is it a Thundercat CDI ?
				Posted: Wed Mar 21, 2012 1:13 pm
				by Alex.
				The dance is a rudimentary diagnostic system, what number does the tacho jump to?
Alex.
				Posted: Thu Mar 22, 2012 10:12 pm
				i think its the foxeye cdi and the needle usually jumps to 8000 then back down
				Posted: Thu Mar 22, 2012 11:54 pm
				by hunter
				I take it your not using the fuel sender,Join together the sender wires and your problem will go away.
				Posted: Fri Mar 23, 2012 8:40 am
				by Alex.
				Why connect the loom together?  That way you lose the fuel light.
I took a picture of the connectors a while ago, over in another thread.
viewtopic.php?f=37&t=27368&p=226584&#p226584
Alex.
				Posted: Fri Mar 23, 2012 8:41 am
				by Kayla850
				hunter wrote:I take it your not using the fuel sender,Join together the sender wires and your problem will go away.
This, and I also had to short the reserve switch as well. You can splice the 400 tank wiring and fuel pump into the 600 loom pretty easily, the colours are the same (I think!)
