Thundercat forks in a 3en2
SteveO916
Bike owned: Ducati 916, GSXR750, XR400R
Post by SteveO916 »
Hi,
i'm thinking of putting thundercat forks in my 3en2 as i know they will fit straight in, but can i (hopefully) use the fzr wheel and spacers (or get spacers made)?
anyone know? anyone done it?
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Re: Thundercat forks in a 3en2
Post by Taggyd »
sure kayla can do you some spacers if they dont fit!
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
I think you'll need to swap the yokes over too. I'm sure the Thundercat forks are bigger diameter.
Post by Evilchicken0 »
The forks are 41 dia so they'll fit in the yokes but you'll need the front wheel etc because the spindle is a larger dia. That might be an issue if the yokes have a different fork spacing.
You could look for a front T'Cat end, and it should drop straight in but you could also look for a YZF750R front end because it's lighter.
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
SteveO916 wrote:Hi,
The forks will fit in the yokes fine, but the FZR wheel uses a 15mm bearing and the Thundercat forks use a 17mm spindle. It's doable but I;m too drunk on g&t to answer properly now! :lol:
www.projection-racing.com
www.pjcfasteners.com
uniquefzrfreak
Bike owned: Harley Sportster 883
Post by uniquefzrfreak »
Get the T'Cat front wheel and discs etc. around 80 to 100 pounds, often with a good tyre, online.
Makes for an easy swap!
