Wont start nc 30
pete_vfr
Wont start nc 30
Well its another post from me i feel like ive rebuilt the bike and it still wont start, it turns over but doesnt fire like theres no fuel now up to date ive:
Replaced spark plugs
Stripped down and cleaned carbs
checked float valve heights and made sure they close and dont pass fuel
compression on the engine is good
checked ht leads and coil packs nice blue spark off each
fuel lines ive blown through no blockages
When shes running it sounds great nice and smooth, problem is i brought her to use on the track to give it ago but cant book a day now out of fear she wont start when i get there, so any other thoughts would be most helpful but i think after this atempt ill be looking for something else, cheers guys pete
hardnutdvd
- Bike owned: RVF400 NC35
Re: Wont start nc 30
have you checked the vacum hose isnt kinked or split? simple and you probably have already, but just a thought. start with the simple things first! :)
pete_vfr
Cheers dude its had the fuel tap mod so the vacum pipe is disconected and capped off, theres fuel in the carbs and it must be sucking up into the chamber because if i just turn it over loads i end up with wet plugs
- Bike owned: VFR400
Remove the spark plugs and lay them on the engine, in the plug caps,and then crank the engine and check for spark.
Morespeedvicar
Hi, maybe squirt a small drop of petrol down each carb inlet. and see if it'll fire up quick like that, if it doesnt run or even fire then it must be spark related.
Hope it helps
Ian
Hope it helps
Ian
pete_vfr
Hey guys the spark plugs all spark fine off the engine case so yeah ill try putting some petrol down the carbs never no how much to put in though dont want to drown the plugs? i will give a try later today and let you know.cheers
If plugs are wet then there must be fuel in the chambers and a spark should ignite it. May be the plugs are too wet? How old are the plugs, do they still spark after you have wiped the fuel off them?
pete_vfr
Hi all right tried starting the bike while sraying engine starter into the carb inlets and even then not even a hint of fireing up its very strange the plugs are new and when taken out they spark lovely and strong blue spark, where i go from here i dont know
What if anything have you changed since the last time it ran? How long ago since it last ran?
- jetblack
- Bike owned: '89 NC30 SEED
Got the firing order the right way round?
