Turn Signal Relay
Turn Signal Relay
Starting to check out my wiring and it looks like the turn signal relay may be shot. Does anyone know of any easy swaps? I saw it shares the same relay with the DR200 but it seems to be different on U.S. models.
- Variablevalves suck
Re: Turn Signal Relay
Should be able to use any twin wire type so long as the wattage is similar, most suzi of the same age will work.
