Starting Problem
Posted: Mon Mar 05, 2012 9:51 pm
Gsxr-400 '94 (GK76a)
It's been off road since 01/01/2002. I brought this bike 2012 and it was a runner baring in mind it's done 4 miles in 10 years ( MOT road test ) I picked it up after having restrictors fitted/MOT/Service etc. got it home and it won't start, the garage had left it in 'Prime' when they set up carbs etc.. so I checked:
Spark plugs:
Black as hell so fitted new ones. Got spark (how strong should the spark look though)
Air filter:
Was full of nuts!! I'm guessing squirrels used it for food storage. New one on order. But in general looked ok
Serviced my arse!!
Battery:
Brand new and %100 charged and on trickle charge
Starter motor:
Jolts bike when in gear and clutch out so that's fine
Fuses:
All new under seat
Anymore anywhere else?
Fuel:
Drained fuel out of carbs
Drained fuel out of tank (off bike)
Added 5l fresh fuel
Carbs have got fuel going to them
Bikes not backfiring
Any ideas?
On my list:
Check if fuel is getting to cylinders
Take off carbs and clean them
Fit new O'rings
Check ignition system with multimeter (how/what to check would be brilliant thanks)
Thank you,
Ricky
( I would search but I'm on phone which makes it very awkward sorry )
Spark plugs:
Air filter:
Serviced my arse!!
Battery:
Starter motor:
Fuses:
All new under seat
Fuel:
Added 5l fresh fuel
Any ideas?
On my list:
Fit new O'rings
Thank you,
Ricky
