Page 1 of 3
possible to fit a 53mm outlet exhaust to nc30?
Posted: Sun Mar 04, 2012 7:04 pm
by xivlia
Hello. i see some great exhausts for yamaha r6 and other 600 cc bikes. and they all have a few mm bigger outlet size obviously due to the bigger cc... but i was wondering if i could fit a 53-54mm pipe onto my TSR's link pipe and just somehow crush the outlet close with a clamp? or would there be too much gap that it would start leaking? oooor another thing, IF there is some sort of extra link pipe i can use please do share
thanks!!
Re: possible to fit a 53mm outlet exhaust to nc30?
Posted: Sun Mar 04, 2012 7:10 pm
by mo haggs
xivlia wrote:but i was wondering if i could fit a 53-54mm pipe onto my TSR's link pipe and just somehow crush the outlet close with a clamp?
dude - you're a tool.
Posted: Sun Mar 04, 2012 7:14 pm
by xivlia
how so? i dont see this being a pig problem... my tsr can and link pipe already doesnt fit in properly.. i have to crush that aswell...
Posted: Sun Mar 04, 2012 7:16 pm
by mo haggs
you shouldn't have to crush anything, either get it repaired (properly) or buy one that fits.
Posted: Sun Mar 04, 2012 7:18 pm
by mo haggs
xivlia wrote:my tsr can and link pipe already doesnt fit in properly
whats wrong with it?
Posted: Sun Mar 04, 2012 7:19 pm
by Man_Named_Dave
mo haggs wrote:you shouldn't have to crush anything, either get it repaired (properly) or buy one that fits.
Although I think you will do it anyway. You do know that it's wrong to do it but you also know that you'll probably do it regardless of the advice you get. It clearly won't function properly with a bodge job.
Posted: Sun Mar 04, 2012 7:37 pm
by xivlia
well its strange because my current pipe is 51mm and the link pipe is like 47-48mm which is a fair gap to close... it came like that wiht the bike, but ive been told its a half TSR system. the can has those slits on the outlet so it can be closed shut with the clamp, when i mean crushed, i mean closed
not crushed as in damaging crushed.
Posted: Sun Mar 04, 2012 8:13 pm
by mo haggs
xivlia wrote:well its strange because my current pipe is 51mm and the link pipe is like 47-48mm
are both mesurements ID? (inside diamater - this means inside the pipe
if so you'll prob find that the link pipe is made from 1 - 1.5mm ms/ss or ti.
so if it is going to fit inside the can it needs to be that much smaller.
so a link pipe made from 1mm ti,
with 48mm ID - will have a 50mm OD (outside diamater - you guessed it
so put a 50mm OD pipe against a 51mm ID pipe and guess what..... it fits,
leaving only 1mm for the clamp to close
Posted: Sun Mar 04, 2012 8:19 pm
by xivlia
yes my measurements are both ID, infact when i slip the pipe on, it moves up and down quite abit... untill i clamp it and use the hanger clamp too...
Posted: Sun Mar 04, 2012 8:21 pm
by Drunkn Munky
Aye stop bodging things it'll come back and bite you in the arse one day. Any can can be made to fit, either get a new inlet cap for the can that fits the link pipe correctly or have a ali sleeve made to take up the difference between the 2, the former is prefered but does require a bit more mechanical know how to fit the inlet although its not rocket science.
