1WG tail pipe diameter
Maelstrom
- Bike owned: MC22, 3TJ1
Hi All,
I am making some stainless exhausts for a 1WG. The bike I have has the tailpipe (the section from the collector to the muffler) and the muffler replaced. I need to know the original outside diameter of the standard tail pipe.
Thanks for your help.
cheers
cheers
https://litetek.co
https://litetek.co
stranglerman
- Bike owned: FZR400 Genesis
Re: 1WG tail pipe diameter
Is that a 1WG as in the Genesis model???? If so it is 50mm outside Diameter..
Maelstrom
Yes Genesis is correct and thanks for your help.
https://litetek.co
https://litetek.co
stranglerman
No problem. I have a full standard system if you need any other info.
