gsxr400 gk73 wont start
Hi guys!
Brought a gsxr400 as a project to do up as my first big bike, the engine used to run, however it has been sat in the previous owners garden for 2 years, trying to get it started today, it turns over but then back fires, sparks on all 4 cylinders got fuel getting to it, not sure where to go from here, is there too much fuel? or a different problem?
Help needed! asap! :) cheers
- Bike owned: GK76SP & ER6F
Re: gsxr400 gk73 wont start
First things to check if it's been stood would be the carbs. They're likely to be bunged up with old fuel.
Secondly, check wiring for corrosion or loose wires. Also, check the battery, it might be low which could stop it starting, even though it's turning over.
carbs have been off and cleaned, i have new plugs on the way, noticed earlier a slight air leak on the float bown of one of the carbs, the bike turns over then occasionaly back fires out of the exhaust, and sometime carb 3 any ideas?
- Bike owned: 1990 gk76a
I would wait untill you get the new plugs mines done that before. New plugs sorted it
Cheers guys!
dont suppose anyones selling a thermostat for it by any chance?
http://a5.sphotos.ak.fbcdn.net/hphotos- ... 3716_n.jpg
i have the one in the top left hand corner spare, only prob is that the connector has snapped off at the white bit, could easily just soldier a wire and a connector joint on there, no idea if it works or not though, just had a big box of spares when i got the bike
well basicaly my thermostat is f***ked, how much would you want for it?
Got the bike running now, gunna do an oil and filter change replace all the leads and plug caps, and need a new thermostat (:
Just bought a brand new thermostat (not housing) cost me £34
from fowlers bristol.
- Bike owned: GSXR400RRSP/SRAD 600
Was it the plugs, then?Damian wrote:well basicaly my thermostat is f***ked, how much would you want for it?
Yeah it was the plugs pal (: seems to be running really well considering the age and how long its been left standing really pleased with it brought a bargain! Not bad for £100 ey! Haha (:
