blue spot calipers
andy83
blue spot calipers
Post by andy83 »
Hi all im new to here and im looking at up grading my brakes to blue spots. Iam needing to get brackets made to move the fork spacing upto 100mm from 86. Does anyone know of someone who can make them up for me thanks in advance. 8-)
Kayla850
Bike owned: Sunn Tzar S2
Re: blue spot calipers
Post by Kayla850 »
andy83 wrote:Hi all im new to here and im looking at up grading my brakes to blue spots. Iam needing to get brackets made to move the fork spacing upto 100mm from 86. Does anyone know of someone who can make them up for me thanks in advance. 8-)
I can do it, and am working on some now.
www.projection-racing.com
www.pjcfasteners.com
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
Which FZR have you got? I've put 5EB R6 Blue Spots on my 3EN1 and they're a direct fit :peace:
andy83
Post by andy83 »
how much does it cost for a set. Thanks all
thunderace
I got mine as a full front system off eBay for £35, all hoses M/C and lever, etc included. With brand new pads too!
Post by Evilchicken0 »
With that caliper bolt spacing you've either got a Genesis or 3TJ. If you've got a Genesis then the 2 pots can be upgraded to 3TJ four pots.
If it's the 3TJ then they aren't bad brakes, fit up braided hoses (It's unlikeley the rubber ones are still on there anyway) clean up the calipers and seals, fit EBC HH pads. if your getting a long travel at the lever then check the discs aren't worn.
Kayla850
Post by Kayla850 »
Evilchicken0 wrote:With that caliper bolt spacing you've either got a Genesis or 3TJ. If you've got a Genesis then the 2 pots can be upgraded to 3TJ four pots.
3TJs are 83mm, so if the Genesis is the same then to be honest, I'd go with EC's recommendation and use 3TJ calipers instead of blue spots.
marti
Post by marti »
I would be interested in a set of adaptor plates to fit blue spot calipers to my 3tj
marti
andy83
Post by andy83 »
Cheers the bike is a 1986 1wg with the gold 2 pot calipers with hh pads and braided hoses. the guy in the bike shop nearly crashed into a wall while free wheeling down the ramp. they really are that bad.
I'd look for the 3TJ calipers and probably the master cylinder too.
You should be able to replace the master or the calipers depending on what you can get.
