Page 1 of 2
hugger help
Posted: Wed Feb 08, 2012 10:08 pm
by jay20jay
I have just tried to fit my rear hugger that I got of eBay. It all bolts on fine on the chain side but I can't fit the bracket that sits by the bottom of the shock as there is nothing to bolt it to
Can anyone help me
Re: hugger help
Posted: Wed Feb 08, 2012 10:21 pm
by arsey30
If it like the RC30 hugger, then the bottom rear link bolt nut is replaced with a longer nut, drilled m6 to fix the bracket to the swinging arm.
Re: hugger help
Posted: Wed Feb 08, 2012 10:26 pm
by jay20jay
Thanks mate any idea where to get one
Re: hugger help
Posted: Wed Feb 08, 2012 10:31 pm
by Drunkn Munky
All the huggers ive had came with a fitting kit, cant remember exactly whats included but its a few bits and bobs, not really something you can just buy off the shelf although if someone can post a pic up of the kit im sure you could knock one up
Re: hugger help
Posted: Wed Feb 08, 2012 10:38 pm
by jay20jay
Ta mate
Anyone got any pics of a kit or anything you have made to do the job
Re: hugger help
Posted: Wed Feb 08, 2012 10:41 pm
by arsey30
If it does fit as RC, then nut is a special, should come with kit.
Something like an m10 fine nut about 20mm long ,threaded half way, the end tapped m6 for the hugger fixing.
Go back to the supplier first, but could be made from a length of 17mm hexagon bar.
Re: hugger help
Posted: Wed Feb 08, 2012 10:47 pm
by jay20jay
I don't no what kind it is as its second hand and the bloke I got it of said he just screwed it to the swinging arm with self tapers which I won't be doing.
That helps tho will look into it 2moz
Re: hugger help
Posted: Wed Feb 08, 2012 10:59 pm
by arsey30
Sounds like you need the nut as stated.
See if the m6 hugger bracket hole lines up with the centre of the linkage bolt, if so measure the length required for the new long nut and tap it half way m10 fine, and half way m6.
Re: hugger help
Posted: Wed Feb 08, 2012 11:09 pm
by jay20jay
Ye that sounds right thanks
Re: hugger help
Posted: Thu Feb 09, 2012 8:58 am
by porndoguk
if i am right in thinking the guy you got it off on ebay sells them without the fitting kit, gav at jap4 sells them for £30 ish, we have a few members who have had this problem.
Rick
