front brakes
front brakes
Hi All,
Have done a bit of searching around, but can't find anything definitive...
Are the front disks for an NC30 the same as a vtr1000?? others??
I have just noticed model numbers etc seem to line up but not for every manufacturer...
Cheers,
Shaun.
Cheers,
Shaun.
- Bike owned: RVF400 - ZX636
Re: front brakes
The NC30 discs are the same as an awful lot of other Hondas.
Re: front brakes
like.........
- Bike owned: NC35
Re: front brakes
honda rs250, cbr400, vtr1000, cbr900, rvf400, cb400, vfr750...list is a bit longer
Re: front brakes
great thanks for that.
Noting it is a bit hard to find race brakes for a VFR400, but they are everywhere for 900's and vtr's!!
Re: front brakes
Race brakes?poomba2hd wrote:great thanks for that.
You can get HRC spec race pads for the standard 4 pots which work extreemly well.. even the stock OE nissin pads are great for moderate to fast track.
Providing calipers are in decent condition.
A common upgrade is fireblade / sp calipers as they are in generally better condition.
I have a mint set of stock calipers on my bike with overhauled seals / pistons / braided lines / o/h master-cylinder and there bloody fierce.
Fantastic brakes, wouldn't really want anything more agressive!
Are you building a race bike?
Re: front brakes
Yeah, race bike. Have to have standard calipers and M/C so just looking to put the best gear i can on.
The standard setup i have works pretty well, however disks are undersize so need to get some new ones...
Re: front brakes
I see.. do you mean the OEM discs are undersize or your specific discs are? Standard calipers? Are these NC30 calipers or just any bog standard bike caliper?poomba2hd wrote:Yeah, race bike. Have to have standard calipers and M/C so just looking to put the best gear i can on.
If you have money to play with you can do a 310mm disc conversion with late Fireblade or SP1/2 calipers (I believe the gold ones are better calipers according to discussion on here, pistons are better? Large pistons and pads)
The standard adapters work with original 296mm discs, I believe the adapters for the 310mm discs are difference.
You will need brake lines also.. the calipers have bigger pistons and pads so should have more bite.
Re: front brakes
He needs to keep the original calipers Neo.
If you want some of the best discs you can buy check out 'braking' brand: http://www.bikehps.com/braking/poomba2hd wrote:Yeah, race bike. Have to have standard calipers and M/C so just looking to put the best gear i can on.
