Mark just been offered!
MarkT
A 1992 sp engine that would be less than £100? Owner lost carbs! Would this fit in my 3TJ frame and would my 3TJ carbs fit? Engine is very good apparently?
Mark
Mark
Taggyd
Re: Mark just been offered!
yes it would fit, it's essentially the same bar more plates in the clutch and a closer ratio gearbox. if you're not sure you can buy it and i'll swap you my rr engine!
carbs should be ok as well but not absolutely sure!
If it is what he says it is then Yes and Yes.
Look on the engine's head, it should be smooth on the sides with no fins
MarkT
Cheers! What about oil cooler don't know if that is with it?
You don't really need it.
MarkT
Brilliant fingers crossed fit tomorrow then!
Taggyd
didnt the sp have an extra connector on the rad for something? or was that on a 600 rad? Can't remember!
MarkT
I do have an extra connection on the rad neck it comes from the back of the cylinder head. The pipes were on the wrong way rround when I first cot it and it boiled over.
Connections are main hose from thermostat, overflow from rad and small hose from engine! Don't really know how mine was made up even now,,,,,,,
Goes to the oil cooler I thinkTaggy wrote:didnt the sp have an extra connector on the rad for something? or was that on a 600 rad? Can't remember!
MarkT
I'm keeping my fingers crossed just what I need as a spare!
