R6 reg/rec from 2010 bike, work???
Posted: Thu Jan 26, 2012 6:42 pm
Hi all, I have in my grubby mitts a 2010 r6 reg/rec, it has 6 pins.
I also have the matching plug with about 6 inches of cable coming out of it, three white wires in a row and above that a red wire and a black wire with a blanked off pin connection between them.
As there are only 5 wires going into this reg/rec and the sixth pin is not in use, can this be used on my NC30??
If it will work, I take it I would be better off to use the original R6 connector soldered to the nc30 loom?
Graham.
Graham.
