daft question
daft question
can anyone tell me what position the fuel tap on an nc30 is at on reserve the word reserve top bottom or side just refitted the carbies after taking 33bhp restrictors out but i stripped them and put the jets emulsions in the rite carbs and iv flattend the battry trying to get it started again just want to make sure im not trying with the bugger turned off
- CRM
Re: daft question
arrow pointing up fuel on, arrow pointing down is reserve. horizontal = off
assume the vacuum pipe is connected correctly on the furthest outside stub and not the one in the middle (breather)
Re: daft question
yep i had the vac pipe connected to the one pointing down instead of the one in the middle of the diaphram less haste more speed as me old gaffer used to say. fired straight up going to post a question in your carb set up thread now cheers feller
