Seat mount point broken NC30
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
Is it fixable? Image
krisztian_andre
Re: Seat mount point broken NC30
CRM
Admin NWAA
Admin NWAA
Post by CRM »
thats normal. and common.
repair with plastex, or use a couple of small self tappers from the underside into the seat base to secure
lizard821000
Post by lizard821000 »
same thing with mine mate, as said, common as hell. iv manedged to fix one side of mine with plastex but iv bought some self adhisive velcro and will be using that laced all around both the seat and fairing. :)
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
+1 plastex. I'd never used it before and found it easy to repair.
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
Exactly the same has happened to mine too...how strong is plastex?
lizard821000
its liquid plastic ! plastic in a bottle. i fixed something with plastex and tested its strength 24 hours later by bending it to see if the fix gave.......it broke at a fresh area of the plastic and not the area fixed lol awsome stuff and easy to use.
krisztian_andre
Le_Blur
Bike owned: 1990 NC30
Post by Le_Blur »
That's the stuff. I had exactly the same thing happen as Lizard. I was flexing the newly repaired joint to see how strong it was, and ended up cracking the fairing somewhere else. It's bastard strong once it's cured.
krisztian_andre
I've repaired it 4 times but tabs keep breaking off because when you take off the seat unit you have to flex it to clear the water reservoir and the rectifier. I think a good solution would be to replace the tabs with thick rubber ones. My question is, what glue should I use to fix the rubber tabs to the inside of the fairing?
