fazer600 engine
				martynfzr
fazer600 engine
hopefully getting a fazer 600 engine for nought just thinking will it fit the 400 as it is losely based on the fzr600 any ideas lads
cheers martyn
						cheers martyn
Re: fazer600 engine
I think it's more a thudercat engine but with different tuning. It should fit ith the usual tweaking.
I don't know if you have a TJ or not but as I recall the Fazer has frame rails so it mounts more like a 1wg. I don't know if it has the top mount points like the TJ but if it has you may need some plates. You'll need to find: downpipes, carbs, cdi and loom for it though.
