3TJ Engine Transplant
Posted: Wed May 07, 2008 7:12 pm
				As a few of you know from my post in the old forum, the engine in my 3TJ started knocking under acceleration the other week.
After checking the engine with a stethoscope, I still wasn’t sure where the noise was coming from so I stripped off the fairings and drained the oil to check for signs of any problems.
I found fragments of metal in the oil, which is never good news. I then dropped the sump and found even more metal fragments. It was pretty obvious that some serious damage had occurred to the engine.
I pulled one of the conrod end caps and found that the bearing shell was pitted and had a fair bit of wear on it. It also looks as if the oil pump pick up/strainer had been fitted the wrong way around by one of the previous owner, which is possibly one reason why this problem has occurred.
Hopefully I have caught this problem before any real damage has been done to the engine. If the crankshaft has survived without any damage I will be happy.
No3 shell bearing, not looking too healthy. The photo doesn’t really show the extent of the damage as it is badly pitted and the white metal starting to flake off.
Until recently I used to keep the bike at the powder coating workshop where I used to work, as I had nowhere to keep it inside at home and I didn’t really want it left outside in the wind and rain after the amount of work I have put into to it.
I have had a sectional fibreglass shed with double doors in the garden for a few years but there was no easy access to it from the road so I threw out all the old crap I have gathered up in it over the years (windsurfers, outboard motors, bits of old cars/boats, etc), took it apart and moved it to the back of my other shed, next to my driveway.
There is enough room in the new shed to easily hold a couple of bikes, I might even squeeze in 3 if I really had to. I will hopefully get a concrete ramp made up to the doors as soon as I have time.
The new shed was really only meant for storing the bike and I wasn’t expecting to be doing major surgery in there. It in nowhere near finished, i haven’t even got the shed bolted down to the foundation, the floor painted or the electricity plumbed in yet but at least it will keep me dry if it rains.
There was obviously not going to be a quick fix to this problem and the only option was to pull the motor out of the bike. It was an easy enough job to drop the engine out, but it certainly helps to get another pair of hands to help steady the engine when you are dropping it down with a trolley jack.
Note the quantity of oil I have managed to spill all over my brand new concrete floor. I didn’t have any old cardboard handy or i would have had that on the floor to try and keep it clean.
The sick motor, soon to be replaced by a healthy 2nd hand engine. I can then recondition the sick one at my leisure and not have to rush to get the bike back on the road. I wouldn’t mind getting the casings vapour blasted to make them nice and shiny.
I find it really handy to keep all the fixings/small parts in one of these storage cabinets, they only cost about £15 and are worth every penny. You can label all the compartments so you know which bolts go where when it is time to reassemble the bike.
Now that the engine is out it gives me the perfect chance to clean up the insides of the frame and a few of the places that you normally cant get too when the engine is in the frame.
