alarm problem
marti
alarm problem
Post by marti »
To cut a long story short. I have a meta 357t v2 fitted to bike 5yrs ago.
It stopped responding to fob, tried new batteries and new fob, no joy.
Tried to follow recode sequence {abacus alarms} no joy.
I can enter pincode ok and alarm disarms then switch ignition on/off 3 times. No beep so no go.
Any ideas?
kevprojex
Bike owned: ktm200exc gsxr400gk71b sv650
Re: alarm problem
Post by kevprojex »
Take it off and bin it, most alarms last about 3-4 years before they start to play up . i have removed lots of alarms that have caused missfires and starting problems , im not a big fan of alarms more trouble than they are worth.
CRM
Admin NWAA
Admin NWAA
Re: alarm problem
Post by CRM »
+1
had a new datatool system 3 fitted to my 916 back in 03 and it was nothing but hassle. i got 6 months before it died and it was 6 months too long. caused all sorts of odd issues and on a Ducati thats already a losing battle.
replaced the loom with a new one and got rid of the datatool once and for all.
the cost saving on insurance was around £20 if i recall, and i would have happily paid £200 more to be rid of the piece of shit from day one for all the hassle it caused.
loom on the 916 has never given me a moment of grief since*
*which is more than can be said for the 2 new rectifiers, air flow sensor, clock sub loom, P1.6M ECU, rear brake light switch.
and coupled with the rebuilt engine, BP subframe, aftermarket parts, 5 spokes etc etc its like triggers broom and not much left is from 1995
Re: alarm problem
CRM wrote:+1
Oh dear, sounds pricey! So I take it pretty much anything electrical on the bike has failed at some point! :P
Who'd have thought an Italian bike would have duff electrics :mrgreen:
CRM
Admin NWAA
Admin NWAA
Re: alarm problem
Post by CRM »
you would think, but really its no worse than a NC really.
one advantage to the ducati loom is that it comes in snap in sections, so you can replace sections of the loom without stripping the bike. very quick and easy - which is handy when the rectifier section burns out every 2 years if using the original 2 wire AC rectifire and not changed to a later type which are pretty well sorted (like fitting the R6 unit to a NC)
the air flow sensor was unlucky, clock section needed changing as i went from a P8 ecu to the 1.6 for the bp subframe, and as such the tacho and loom are slightly different so not exactly a failure as such.
parts are as cheap and plentiful as NC's so apart from the main service which most will get a dealer too they are not too bad on the old desmo engined bikes
Dynamohum
Re: alarm problem
Post by Dynamohum »
had a similar problem with a meta alarm on my old rrx fireblade it totally shit itself imobilising the bike :x eventually got it removed and binned completely. the datatool alarm i had on a cb13 used to play up every now and then and would only disarm using the pin code . must say it was not amusing listening for audible beeps in rush hour traffic in bilbao :roll: as has been said most bike alarms have a shelf life living in a hostile enviroment on a bike hot/cold/damp etc. best thing to do is get it removed and if you must have a alarm get one of the non soldered into loom types cyclone or similar.
Re: alarm problem
CRM wrote:you would think, but really its no worse than a NC really.
Yeah I know, I was just making a (crappy) all Italian bikes have crap electrics comment!
Old bikes are always money pits.. parts wear out naturally and some bikes just have bad design issues.
CRM
Admin NWAA
Admin NWAA
Re: alarm problem
Post by CRM »
i will say though the mille i had was really good electrically. loom was bound nicely and routed well, and of suitable guage wire.
i know ducati's were known for having there wiring made by sicilian peasants, but the 999 onward bikes seem to be spot on.
the old desmo powered bikes were a bit problematic if not kept on top of though thats a fact.
marti
Re: alarm problem
Post by marti »
Thanks guys, think ill bin it, but id better check with my insurane.
marti
Re: alarm problem
Post by marti »
If i remove my alarm, my insurance would be invalid or i could pay an extra £77 premium!
New alarm off ebay £100.
Anyway, rang meta systems who put me on to a guy called basil,
who told me to put the pincode in then turn the ignition off/on x3 as quick as possible and not wait for all the idiot lights to come on each time.
It bloody well worked! Got a beep, carried on with sequence. Sorted
