help needed fitting a m-max box
ive got a gsxr 400 gk73a sp and having trouble fitting a m-max box can anyone help me out??
cheers jack
cheers jack
Re: help needed fitting a m-max box
it has a plug doesn;t it?
So..it pluigs in?
Get us some pics dude..
Welcome to the site
We'll sort it, but surely you are doing something a touch wrong?
So..it pluigs in?
Welcome to the site
- CRM
please don't double post.
As Mark said, it simply plugs into the loom to fool the CDI your not exceeding the 115mph marker and keeps it going (not by alot though)
yeah but im not sure where to plug it in and the little single wire has no where to go http://i267.photobucket.com/albums/ii31 ... Y/MMAX.jpg
- Variablevalves suck
Do you Know where the large blocks plug in? and are the two single wires black with a white trace?
Is the Mmax definitely listed for the 73a as you can unrestrict a 73a with a simple resistor and the Mmax boxes ive seen only have three wires.
yeah its for a 73a and i dont know i tried on the cdi it fits and then i took it up the road to see if it had worked aznd it hadnt and the little wires have no where to go
The gk73 is restricted via the gear sensor, it tells the cdi what gear you are in and then the cdi cuts the spark.
The wire is green with a yellow tracer and will have to be part of the wiring that plugs in to the Mmax.
What colour are the single wires? are they blk/wht? if so they are neutral/return wires.
yeah its black has anyone got a picture as i havent got clue where sposed to be plugged in i tried it in cdi but had no where to put single wire
Hi, sorry to go over things but are the single wires black or black with white trace line.
sorry i was mistaken their red with black line
