bike cut out help!
joshmega
Bike owned: nc 30 zx6r sv650
bike cut out help!
Post by joshmega »
i was driving my bike and it suddenly just cut out on me pulled over to the side of the road and it would start of the starter button it would bump and only stay running for a few secondes then cut out any ideas?
Re: bike cut out help!
Start simple.
Vacuum hose still attached and not split etc?
Sounds like fuel to me..
joshmega
Post by joshmega »
has petrol in it wouldnt start after and the battery went dead it may be the regulator
iDemonix
Bike owned: '92 NC30
Post by iDemonix »
Was the battery already did or did you flatten it from attempted starting? Have you checked the vacuum pipe? On the right hand side of the bike, look through the hole in the rear cowling, opposite to the fuel tap hole, check the pipe is coming off the fuel tap (facing forwards on bike) isn't kinked, split and is connected. I had the same happen to me once and turned out my pipe had kinked
joshmega
Post by joshmega »
it started fine about 5 minuites into riding it just tottaly cut out on me pulled over tryed to start it just would do anythink then tryed to bump it it started but only for about 5 secs then cut out then would not bump at all
Cammo
Post by Cammo »
CMSMJ1 wrote: Vacuum hose still attached and not split etc?
+1
Man_Named_Dave
Bike owned: NC30(K)
Post by Man_Named_Dave »
Something similar happened to me 3-4 times in the summer. I got a fuel hose from Rick Oliver for a fiver and it never happened again.
joshmega
Post by joshmega »
its making a noise coming from under the seat though, sound like its struggling to turn over so surley if it was to do with feul it wouldnt make the noise
Bike owned: VFR400
Post by magg »
Pull the seat and you will find the battery and other parts of the start/charging system. Might be a loose connection and the noise is the arcing contact.
hannakournikova
Bike owned: NC30, NC35 & SP2
Post by hannakournikova »
joshmega wrote:its making a noise coming from under the seat though, sound like its struggling to turn over so surley if it was to do with feul it wouldnt make the noise
like a very fast clicking?
