idle speed nc21
- Bike owned: vfr400 nc21
idle speed nc21
hi guys
what is the idle speed of my nc21
and which carb is fixed am going to attempt to balance carbs
do you have to take tank right of to do this
cheers dave
cheers dave
Re: idle speed nc21
The carb with no adjustment screw is the fixed one! This is cylinder 2. front left.
The screws are underneath the carbs so tank can stay on, tricky to get to though.
idle speed should be 1300rpm.
balance the carbs slightly higher.. perhaps 1600rpm
Re: idle speed nc21
once again thank you sir
