Running on 3
Running on 3
So my gk76a is running on 3 cylinders, cylinder 4 is the culprit. But why is it running on 3? Ive got spare coils to swap over, but what wires go to the coils?
Thanks in advance
Thanks in advance
- Variablevalves suck
Re: Running on 3
If it runs on 3 only you can swop 1 and 4 over and see if the non running cylinder swops from 4 to 1, if not then its something else, spark plug or carb. If you swop leads and plug and it stays on 4 id say its the pilot system on 4.
Re: Running on 3
Thanks for your reply....
Thats another thing ill check, if i get stuck i can always give Darren a call.
Re: Running on 3
Ye if the motor is ok- valves and rings, the only time ive had a motor drop on one cylinder apart from duff plug or lead has always been due to some crap in the pilot jet/circuit.
