rearsets and damper
wedge
rearsets and damper
Post by wedge »
has anyone bought or know what rearsets you cab get????..also steering damper??...i would rather have a pair still uses the factory master cylinder and brake light switch.
kaighn80
Re: rearsets and damper
Post by kaighn80 »
i bought a cheap yoshi copy rear set and they use the standard stuff, not badly made either, not great but not bad, its the price that did it though, you could buy 5 sets of the cheap ones for the price of a good set.
Post by Evilchicken0 »
SES do a pair for the 3TJ they use the standard ger too. The can will touch down first though
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
ive got a 'universal' damper, it goes around the fork leg and is secured onto the metal bracket up on the side near the front of the frame. you can drill and tap the frame to mount them too. my road frame had the holes from where it was used as a race bike.
I've got a generic damper if you want one
wedge
Post by wedge »
thanks for the offer,im watching one on the fleabay at the moment....what i really want is a factory road sp seat unit..
Taggyd
Post by Taggyd »
racombi weiss, i think that's how you spell it, do replica ones in gel-coat white. not bad bits of kit.
edsashed
Post by edsashed »
hi evilchicken i would be intrested in the damper if it comes with a fitting kit etc
sorry no fitting kit, but you could ask Kayla to make you one
cagiva996
Bike owned: 2 FZR4/6,FZS600,YZFR1
Post by cagiva996 »
just a thought about the steering damper,do you really need one? my 3tj2 has never tank slapped or got unstable on road or track and the roads on the iow are awfull,even with the yokes pulled thru the yokes either 5 or 10mm,the rear raised by 8mm, and racy track tyres fitted its never got out of shape.not trying to be a killjoy but you could save the cash and spend it on something else that you may really need.or perhaps i aint trying hard enough! :oops:
