sticker set for red white blue 3en2
Posted: Sat Oct 22, 2011 11:36 pm
by kaighn80
does anyone know where i can get a standard set or a replica set of stickers made up for a 3en2 the nicest of all the colours (red white and blue) its the one with the red speed blocks.
Re: sticker set for red white blue 3en2
Posted: Sat Oct 22, 2011 11:48 pm
by Evilchicken0
Do you have a picture of the stickers you want and / or do the panels have some of the stickers already on ???
I used Image Works they were good but took a long time.
Posted: Sun Oct 23, 2011 10:33 am
by kaighn80
yep want it just like this but with a blue stripe under the red stripe on the tank with the yamaha cut out of it so the white shows through.
Posted: Sun Oct 23, 2011 11:30 am
by Evilchicken0
If you keep it standard you won't need to respray the tank, you can just cut the laquer back with some G4 compound (G4 is for old paint G3 for new)
Personally, I'd make the blue stripe on the tail end square on the same line as the red speed block, then change that big red one to a white numberboard (black outline)
Posted: Sun Oct 23, 2011 1:35 pm
by kaighn80
problem with cutting back the paint is its black and yellow and looks gash, I was thinking the same thing with the number board but having it with white numbers over the red.
Posted: Sun Oct 23, 2011 5:16 pm
by Evilchicken0
Ahhh rubbish paint that makes the difference
Posted: Sun Oct 23, 2011 8:58 pm
by kaighn80
more rubbish colours than rubbish paint but it was always going to be red white and blue anyway
