what the hell is my bike....like a mix up..
wedge
Post by wedge »
right i had free couple of hours to look at the bike i bought..so sarted to strip it downs alittle....frame and swingarm are RR model..fine.took tank off its got mikuni flatslide carbs....the cdi box..BB7208,3tj-00....boy on ebay selling cdi the same says its rrsp???....also what i thk engine numbers..back of engine casing infront of rear shock..is like..544646..i thk from memory......i also rev it toady and it went right off the cloaks past the 16000rpm..any idea what parts are sp..or rr??
Re: what the hell is my bike....like a mix up..
Post by Evilchicken0 »
Well need some pics to be sure what it is. Lots of people see Mikuni and think they're flatslides but they turn out to be CV's (made by by the same company see), not saying they aren't though ;)
KIYOSHI
Post by KIYOSHI »
The number on the back of the engin, infront of the shock is the code for the bearings on the main journals and not the engine number, you will find the engine number just above the clutch cover but it will only say 1wg and nothing else.
The carbs are mikuni CV not flat slides, RR ones have one removable air jet and the SP carbs had two.
BB702 is an SP cdi, if the bike revs to 16000rpm then the cdi is de-restricted,,,,,,,,,be warned DO NOT rev the bike that high unless you want to shag the crank, it may not have had the oil way modded and tbh, reving anything past the red line in neutral is asking for trouble.
Post as many pics as you can,,,,,,,,,dont suppose you bought the bike off ebay a few weeks ago? Black fairing??
wedge
Post by wedge »
i only rev'd it the once to find out...it has no MOT..so only way i could find out...no its a pretty cool looking Valvoline race rep...yeah...1wg is the only numbers i could find,just what im thinking i stay 45mins from knockhill so alot of wee bikes you find up here are ex race/track bikes..it also has the sp carbon can fitted,i was trying to find out if there was other way to find out what the motor was rr or sp..i know about the extra cooling pipe to the oil filter.
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
the clutch will have 9 plates on an sp. but you'll need to open it up to find out!
Vales are different too and I think the springs are a different colour to the RR
The SP standard can is the same as the RR's ... they're heavy too
wedge
Post by wedge »
yeah evil chicken it is heavy..sounds ok....think im going to get the r6 shock conversion for it...like said started pulling it apart needs agood clean and i think a rocker cover gasket aswell.....does anyone know if the speedo converter can fit..looks tight behind clocks and even down at the fork end looks a bit close.
You need a GOLD one at the fork leg end.
It won't fit behind the clocks.
