nc30 Battery flat
rob b
Bike owned: nc30
nc30 Battery flat
Post by rob b »
Hi guys I wonder if you could help me?
Went for a spin today just a small one. Went about 30 or so miles stopped for a chat bike started ok but my mates were complaining that my brake lights & indicaters we very dim. Didn't think anything. Started off again went for about 10 or so miles, stoped at a junction and I staled the bike then it would not start just a clicking nose. Rolled down the hill & it bump started strait away got home put the bike in the gararge & it still as if the battery is flat. I just hope its just the battery as its been standing for about 3 weeks I should of put it on the charger while it was standing
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: nc30 Battery flat
Post by hardnutdvd »
i would say classic reg/rec problems.. or possible alternator issue if the reg/rec proves good.
Bike owned: VFR400
Post by magg »
How old is the battery? Charge the battery and then load test it by measuring the voltage while trying to start the bike with the kill switch on, only run the starter motor for 20 seconds. Battery voltage should not drop below 10 volts. A larger drop would suggest the battery has passed away. If battery ok, measure the battery voltage while engine is running, should be around 13-14 volts no matter what the electrical load provided rpm >5000.
Neosophist can also provide a link to a more comprehensive electrical system test program.
It is recommended that batteries be trickle/float charged if left unused for extended periods, compensates for the internal discharge characteristic of lead/acid batteries.
philfingers
Bike owned: NC30 Type 7
Post by philfingers »
rob b
Bike owned: nc30
Post by rob b »
thanks guys the minute i get chance i will check them out.
thanks.
rob.
rob b
Bike owned: nc30
Post by rob b »
One more question.
When out on the ride the bike ran fine even when bike cut out & bump started it went fine ,would this be the case if the geny was nackered.
But I will get my mate round to check it with his volt tester i'm not to clever when it comes to wires.
Thanks.
Rob.
Bike owned: VFR400
Post by magg »
Could be alternator, rect/reg or battery, or any combination of the three. I would suggest you start by checking that the battery can hold a good charge, bad batteries can give the rect/reg a hard time because the rect/reg uses the battery as a reference voltage to control the charging process. Then check the alternator has a good output. If those two are ok it leaves the rect/reg as the most likely problem.
rob b
Bike owned: nc30
Post by rob b »
Hi Guys.
I checked the battery today & the readings are.
With the lights off is 13.42
With the lights on is 12.30
Any ideas ?
I must say when I went for the blast when the bike cut the battery was'nt fully charged.
Thanks.
Rob.
Bike owned: VFR400
Post by magg »
Lights off 13.42 is ok but with lights on test what was engine rpm. You need to run 5000 rpm to test with lights on, alternator does not have enough ouput at lower engine speed to support the lights on load.
rob b
Bike owned: nc30
Post by rob b »
Thanks.
I forgot to say I was running at between 5000 to 5500 rpm.
Cheers.
Rob.
