Is there no wiring diagram for GK73A SP?
Posted: Sat Oct 15, 2011 3:53 pm
by asantirims
Can anyone help me with the wiring diagram for the GK73A SP?
Or is'nt one????? Please let me know ASAP :peace:
Regards Jake
Re: Is there no wiring diagram for GK73A SP?
Posted: Sat Oct 15, 2011 10:14 pm
by Variablevalves suck
And before anyone asks its only available in Japanese.
Posted: Sat Oct 15, 2011 10:53 pm
by asantirims
Thanks chirs, Found out my bike isn't sparking so will have to check everything out on the electrical side!
Posted: Sat Oct 15, 2011 11:04 pm
Are all plugs not sparking? and do you get 12v at each coil, not forgetting to check the fuse first.
Posted: Sat Oct 15, 2011 11:55 pm
by asantirims
Nope no spark atall, I have checked the coils and they are both reading 12v each side, the fuses are also fine, my uncle told me it may be the CDI, which in that case, it will be extremely hard and expensive to replace as i think i had read a thread that said the SP models wont work with a normal GK73A CDI and the SP CDI's are hard to come by!
:pray:
Posted: Sun Oct 16, 2011 12:04 am
More likely to be the pick up trigger on the LH side of the bike rather than the cdi, you can check the resistance using an ohm meter and i think its between 95 and 110 ohms.
