Is there no wiring diagram for GK73A SP?
asantirims
Post by asantirims »
Can anyone help me with the wiring diagram for the GK73A SP?
Or is'nt one????? Please let me know ASAP :peace:
Regards Jake
Variablevalves suck
Re: Is there no wiring diagram for GK73A SP?
Post by Variablevalves suck »
And before anyone asks its only available in Japanese.
asantirims
Thanks chirs, Found out my bike isn't sparking so will have to check everything out on the electrical side!
Variablevalves suck
Are all plugs not sparking? and do you get 12v at each coil, not forgetting to check the fuse first.
asantirims
Nope no spark atall, I have checked the coils and they are both reading 12v each side, the fuses are also fine, my uncle told me it may be the CDI, which in that case, it will be extremely hard and expensive to replace as i think i had read a thread that said the SP models wont work with a normal GK73A CDI and the SP CDI's are hard to come by!
:pray:
Variablevalves suck
More likely to be the pick up trigger on the LH side of the bike rather than the cdi, you can check the resistance using an ohm meter and i think its between 95 and 110 ohms.
