what other yam fits 3tj
wedge
Post by wedge »
i just bought an 3tj....what other yam fits..i know 600 motor fits also r6 shock..but what else caliper etc...does a uk speedo work off other yam???
Re: what other yam fits 3tj
Post by Evilchicken0 »
No other calipers fit.
No other forks fit (they're too long).
You need an extension piece for the R6 shock.
You can put stickers on it though :peace:
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
Calipers from
TZR250 3MA and 3XV
R1-Z
FZR250 3LN
and some 90s Triumphs all use the same 83mm calipers, but they're the same so aren't any better :grin:
If you try and fit other forks then you'll probably run into problems with the screen brace because the 3TJ forks are really short and most other fork tops hit the brace.
www.projection-racing.com
www.pjcfasteners.com
wedge
Post by wedge »
if i was to fit a 600 motor what would i need...loom,clocks..etc????????
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
the search is your friend, or even the sticky about doing it perhaps......
