Worth buying - for spark plug removal.
				MarkT
http://www.machinemart.co.uk/shop/produ ... 0extension
I hated getting my spark plugs out specially 2 and 3!
For me the above works really well and makes getting the plugs out from the top a doddle!
You may wish to give it a try?
Sent from my iPhone
Sent from my iPhone
- Hogdigerdy Dog
Re: Worth buying - for spark plug removal.
looks pretty good and a reasonable price too
but what's it like for putting the plugs back in,
when you take em out there solid so easy to locate the plug and simply undo
when you put em back in they need to be located correctly into the head, or you'll cross thread em
some of these wobbly bars make that next to imposible
				MarkT
I have found it really good with a good socket on the end with rubber in it. I used my fingers to guide it into place no probs. I will say that with the lower fairings off it is easy to look though the top of the head and you can see how to slightly bend the extension and fit straight in. I will say that I have only done this ever by fitting the plug in the socket first! To drop the plug and then try and do it would be nigh on impossible I would think! It really does work for me that's why I recommend it.
